Posted: 2025-07-01 01:54 AM
Is it possible for Geo SCADA to input rainfall data from an external source and display via its internal map feature?
Posted: 2025-07-31 08:01 AM
You could create a database item or DataTable or DataGrid row for each XY co-ordinate for which you have data. Then import the source data values into these items.
Then create a query which lists their assigned Lat/Long and values, linking it to a query layer in the map.
You could write a VB or Python script to interpret GRIB source and insert into Geo SCADA.
See:
https://github.com/GeoSCADA/Utilities-and-Examples/blob/main/PythonSamples/SetPointValue.py
and
https://spire.com/tutorial/spire-weather-tutorial-intro-to-processing-grib2-data-with-python/
Posted: 2025-07-04 05:53 AM
What format is the rainfall data? If it's a WMS map - add as a layer to maps.
If it's a matrix of values, you could store each in a point, set their Geo positions, then have a query layer which renders them into a map. You can animate symbol size and colour to indicate level.
Posted: 2025-07-07 01:46 AM
Steve
The format would likely be GRIB2 (GRIdded Binary version 2) or if rendered prior to input then CSV.
See:
and
