[Imported] Script to generate Crystal Report
Select a Country
  • Remote Operations
  • [Imported] Script to generate Crystal Report
sbeadle
sbeadle Champion
335
AndrewScott
AndrewScott
125
BevanWeiss
BevanWeiss
103
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
sbeadle
sbeadle Champion
Champion
Posted: ‎2019-10-26 03:03 AM . Last Modified: ‎2023-05-03 12:38 AM
>>Message imported from previous forum - Category:Scripts and Tips<<
User: admin, originally posted: 2018-10-19 19:45:51 Id:160
**_Andrew:
Good morning all, i wrote a script that generates and exports a crystal report (that works fine) after the export the script is supposed to change the value of a few points.
ex._**
_call Server.SetOPCValue("1")
Gen.Interface.Generate
Exp.Interface.Export
call Server.SetOPCValue("2")
call Server.SetOPCValue("3")_
**_value 1 changes, but 2 and 3 do not. What am I missing here?
Thanks, Andre_**
AWoodland:
SetOPCValue takes two parameters, the property you are changing and the value, make sure you provide both.
____________________________
**_Andrew:
Here is a copy of the exact logic i currently have. It's working until i get to
"call Server.SetOPCValue("~HFOTCO.Pipeline.OMNI.Delivery Data.Points.Product Reset", 1)"_**
_sub endBatchNew
DIM Gen, EXP
Set Gen=Server.FindObject("~HFOTCO.Pipeline.OMNI.Reports.Batch.~OutBound Batch Report")
Set Exp=Server.FindObject("~HFOTCO.Pipeline.OMNI.Reports.Batch.~OutBound Batch Report")
if server.thisobject.checkaccess("CTL") = true then
ret = msgbox("Are you sure you want to end the current batch?", vbExclamation + vbyesno + vbDefaultButton2, "WARNING!!!")
if ret vbyes then exit sub
call server.setopcvalue("~HFOTCO.Pipeline.OMNI.Delivery Data.Points.End Batch and Print",1)
Sleep(15000)
Sleep(5000)
sleep(1000)
Attached file: (editor/6f/gax8zjmrut0u.jpg), SFC.jpg File size: 22866
  • SCADA
Replies 0
