[Imported] Relative References in Embedded Lists Query Tab
  • Remote Operations
  • [Imported] Relative References in Embedded Lists Query Tab
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-11-05 01:55 PM . Last Modified: ‎2023-05-03 12:33 AM
>>Message imported from previous forum - Category:Scripts and Tips<<
User: mchartrand, originally posted: 2018-10-25 18:56:39 Id:272
_______
**_Chadam:
Hi Guys,
Do embedded lists support relative references? I will like to search for Points in the Current Folder with the text "Run" in the Fullname.
My WHERE syntax doesn't appear correct._**
_SELECT
"FullName" AS "~FullName", "Id", "Foreground", "Blink", "Background", "CurrentStateDesc", "CurrentQualityDesc"
FROM
CDBPOINT
WHERE
"FullName" LIKE '..Fullname.%Run%'
ORDER BY
"~FullName" ASC_
___________________________
aneeskp:
Hi Chadam,
Relative references can done through animations of List.
Double click the list and click animations. Now in the sql property enter the following:
'SELECT "FullName" AS "~FullName", "Id", "Foreground", "Blink", "Background", "CurrentStateDesc", "CurrentQualityDesc" FROM CDBPOINT WHERE Fullname Like ''' + ".FullName" +'.%Run%'' ORDER BY "~FullName" ASC'
You can view the populated query with actual value of the relatively refered fullname in the Query tab.
Not sure if there's any other workaround, ideally this should work
Cheers ! 🙂
dmercer:
A little trick that I find useful when doing this, is to break up the lines in the animation expression by putting the + at the end of each line. It makes it much more readable when you have to make long queries in an animation.
aneeskp's query could become:
_'SELECT "FullName" AS "~FullName", "Id", "Foreground", "Blink", "Background", "CurrentStateDesc", "CurrentQualityDesc" ' +
'FROM CDBPOINT ' +
'WHERE Fullname Like ''' + ".FullName" +'.%Run%'' ' +
'ORDER BY "~FullName" ASC'_
**_Chadam:
You guys are legends. Works like a charm. Thanks for the quick responses._**
  • SCADA
Replies 0
