[Imported] ODBC driver for ClearSCADA failed frequently
  • Remote Operations
  • [Imported] ODBC driver for ClearSCADA failed frequently
sbeadle
Kirk sbeadle Kirk
323
AndrewScott
Admiral AndrewScott
118
BevanWeiss
Spock BevanWeiss
100
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-11-05 12:54 PM . Last Modified: ‎2023-05-03 12:36 AM
User: florian, originally posted: 2018-10-24 22:00:20 Id:209
**_sonicsie:_**
**_System description:_**
**_We have a redundant ClearSCADA servers with 2 permanent standby, with 11 ODBC connections with 40 Queries and around 200 Variables in the pilot phase and its expected the full system will be around 200K._**
**_Issue description:_**
**_I noticed that ODBC driver failed frequently( almost every 2 Mins) on the connection and I am getting the alarm_** on "Connection1_**
**_Driver Failed" for all connections in the alarm page, after more investigation for the log file for the driver I found that the driver stopped unexpectedly and it is Restarting. As the following;_**
**_26-FEB-2018 12:19:59.749 098C [SVRTHR] 28 Connection 3 failed with error 10053_**
**_26-FEB-2018 12:19:59.749 08B8 [SVRADVISE] 1:00 Network link failed, reason 'Connection 0 failed with error 10053'_**
**_26-FEB-2018 12:19:59.749 08B8 [SVRADVISE] 1:00 Closing Socket 0x2fcc_**
**_26-FEB-2018 12:19:59.749 08B8 [SVRADVISE] 1:00 Connection will be retried on Advise Thread Timeout, Backoff count is now 1_**
**_26-FEB-2018 12:19:59.750 098C [SVRADVISE] 1:00 RemoveLink-1: Events 0, Links 1_**
**_26-FEB-2018 12:19:59.750 098C [SVRADVISE] 1:00 RemoveLink-2: Events 0, Links 0, State Closing_**
**_26-FEB-2018 12:19:59.750 098C [SCXDriver] 28:03 QP Deleted_**
**_26-FEB-2018 12:19:59.752 062C [DRV] Odbc Driver stopped unexpectedly. Restarting_**
**_26-FEB-2018 12:19:59.752 062C [DRV] Odbc State 3 (Running), Event 3 (Stopped), Next State 1 (Stopped)_**
**_26-FEB-2018 12:19:59.752 062C [DRV] Odbc Action 7 (Check Stop State)_**
**_26-FEB-2018 12:19:59.752 062C [DRV] Odbc Stopped, Uptime 146.002518 seconds, Failure Count 53, Exit Code C0000094_**
**_26-FEB-2018 12:19:59.752 062C [DRV] Odbc State 1 (Stopped), Event 0 (Start), Next State 2 (Starting)_**
**_26-FEB-2018 12:19:59.752 062C [DRV] Odbc Action 0 (Set Timeout)_**
**_26-FEB-2018 12:19:59.752 062C [DRV] Odbc Starting. Process has 30 seconds._**
**_26-FEB-2018 12:19:59.752 062C [DRV] Odbc Action 4 (Run process)_**
**_26-FEB-2018 12:19:59.752 062C [DRV] Odbc Starting C:\\Program Files (x86)\\Schneider Electric\\ClearSCADA\\DriverOdbc.exe_**
**_26-FEB-2018 12:19:59.752 062C [DRV] Odbc Started, Pid = 3640_**
**_And the driver error count increases as per this screenshot and the driver log in this link_**
![]((see attachments below) pc/q50sla3f4va3.png "")
sbeadle:
I suggest you contact tech support with this query. They may want to see snapshot files and server logs. (Do not post here as they contain your private data).
Attached file: (editor/pc/q50sla3f4va3.png), errodbc.png File size: 112889
Attached file: (editor/2e/b5u2occmf8qv.log), DB_003.log File size: 21376892
  • SCADA
Replies 0
