[Imported] MS SQL Server Linked Server to ClearSCADA 'Access denied'
  • Remote Operations
  • [Imported] MS SQL Server Linked Server to ClearSCADA 'Access denied'
sbeadle
Kirk sbeadle Kirk
323
AndrewScott
Admiral AndrewScott
118
BevanWeiss
Spock BevanWeiss
100
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-11-05 01:16 PM . Last Modified: ‎2023-05-03 12:35 AM
User: florian, originally posted: 2018-10-25 16:18:27 Id:238
**_bevanweiss:_**
**_Hey all,_**
**_I'm trying to use an MS SQL Server to do some reporting (using MS SSRS), however when I'm trying to query the linked server for my 2015R1 (or 2014R1.1) ClearSCADA servers I'm getting an Access denied error as such:_**
_Msg 7399, Level 16, State 1, Line 1_
**_The OLE DB provider "ClearSCADA.OleDBProv" for linked server "CLEARSCADA" reported an error. Access denied.
Msg 7350, Level 16, State 2, Line 1_**
**_Cannot get the column information from OLE DB provider "ClearSCADA.OleDBProv" for linked server "CLEARSCADA"._**
**_I'm passing in a valid username / password, the connection all works._**
**_The query I'm trying is:_**
_SELECT TOP(10) FullName_
_FROM CLEARSCADA..Core.CDBPoint_
**_Has anyone seen this before (and resolved it)?_**
**_I'm using SQL Server 2016 CTP2, so it's possible it's a bug somewhere in this... although it would surprise me a bit._**
AWoodland:
Got any DBClient logs? Might need to enable them as only DBClientNamed are enabled by default, not DBClient.
I do remember people in the past reporting issues with MSSQL and it assuming a username rather than using what was configured (it is possible that the username it was trying to use was the same as the connection name for some reason, that rings a bell). I can't remember the specific details but the DBClient logging should show which user the connection is trying to use and might explain things.
groyderula:
Thanks for the suggestion. I contacted technical support and they provided an updated article.
  • SCADA
Replies 0
