[Imported] Generate Reports of system changes SQL Export
  • Remote Operations
  • [Imported] Generate Reports of system changes SQL Export
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-11-06 02:53 PM . Last Modified: ‎2023-05-03 12:25 AM
990
User: ROVSCADAENGINEER, originally posted: 2019-04-16 03:08:13 Id:407
I am wanting to generate reports of system changes with an SQL export done at timely intervals.
I am wondering which schema to query.
I understand that SCADA has an option where you can see all the "property changes" made on the system for a server. However when you observe this list I am unaware of anyway to see which schema class this is coming from. Does anyone have any idea how I might do this?
  • SCADA
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-11-06 02:54 PM
Reply From User: dmercer, posted: 2019-04-16 05:46:07
In ClearSCADA lists, you can right click and then click on Edit Query to see what query it uses. In this case the default for property changes is:
`SELECT TOP( 1000000 )
"RecordId", "RecordTime", "ObjectName", "FieldName", "OldValue", "NewValue", "User", "OriginDesc"
FROM
CDBCONFIGCHANGES
WHERE
( "RecordTime" BETWEEN { OPC 'H-23H' } AND { OPC 'H+1H' } )
ORDER BY
"RecordTime" DESC`
Reply From User: ROVSCADAENGINEER, posted: 2019-04-16 21:27:15
That's extremely useful to know dean. Thankyou very much!
sbeadle
Kirk sbeadle Kirk
Kirk
FROM
CDBCONFIGCHANGES
WHERE
ORDER BY
"RecordTime" DESC`
