[Imported] Exporting ESD helpScreens
  • Remote Operations
  • [Imported] Exporting ESD helpScreens
sbeadle
Kirk sbeadle Kirk
319
AndrewScott
Admiral AndrewScott
114
BevanWeiss
Spock BevanWeiss
97
EcoStruxure™ Geo SCADA Expert
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-11-26 01:56 PM . Last Modified: ‎2023-05-03 12:21 AM
912
User: kprocope, originally posted: 2019-09-23 20:24:30 Id:523
Hi, is there a way to export all the ESDs helpscreen found in the ESD Diagnostic screen when you click on a single ESD, then click view and the help button?
I need to export all the HelpScreens for each ESD so that a user could view all the valves information associated to an ESD.
  • SCADA
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-11-26 01:57 PM
Reply From User: sbeadle, posted: 2019-09-24 09:04:11
Do you mean take a screen dump (jpg or png) of mimics?
Reply From User: KylePaynter123, posted: 2019-09-27 12:19:46
We will try to do a screen dump but I think she means export all the images
Reply From User: BevanWeiss, posted: 2019-09-28 00:20:04
What context is ESD here?
It's certainly not a ClearSCADA term. Nor is ESD Diagnostic screen.
I assume that this relates to specific functionality put in place by an integrator for a specific customer system.
In this situation it will depend on how the integrator has stored this information within ClearSCADA.
It's possible that it's stored as a series of mimics, in which case these could be opened within ViewX and screenshots taken of each.
It might be a single mimic with animations to drive the displayed appearance, in which case taking screenshots would be a little more complicated, since it would need forcing of animation values.
It might all be derived from a database table somewhere, in which case accessing the database itself and massaging this into the data form you want is likely the best option.
sbeadle
Kirk sbeadle Kirk
Kirk
