[Imported] Export Value Map
  • Remote Operations
  • [Imported] Export Value Map
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-10-26 02:15 AM . Last Modified: ‎2023-05-03 12:39 AM
>>Message imported from previous forum - Category:Bulk Edit Tool<<
User: mchartrand, originally posted: 2018-10-19 13:19:32 Id:141
This is a re-posting from the obsoleted (October 2018) "Schneider Electric Telemetry & SCADA" forum. The original posters' identities have not been included. Schneider Electric is not responsible for the content of these posts.
**Is it possible to export/edit/import the contents of a Value Map using the bulk edit tool?
I have a rather large REAL value map to modify and using Excel or other external program would be a lot easier.**
__________
From my experience.. No.
The value maps aren't really a big collection of properties that the Bulk Edit tool would handle, it's mappings are really only accessible via scripting and method calls.
Excel would be able to do it, but you'd have to use a VBA macro to achieve this.
Depending on what kind of maps you need to modify you'd do well to look in the schema starting at https://localhost/schema/CValueMap
If you need to deal with strings or bits these become a bit of a special case, but most others fit under https://localhost/schema/CTypedValueMap
a combination of the various methods from these types should get you what you want... but it won't be as easy as you'd like.
  • SCADA
Replies 0
