[Imported] Collation used by ClearSCADA for the ORDER BY clause in SQL queries
  • Remote Operations
  • [Imported] Collation used by ClearSCADA for the ORDER BY clause in SQL queries
sbeadle
Kirk sbeadle Kirk
323
AndrewScott
Admiral AndrewScott
118
BevanWeiss
Spock BevanWeiss
100
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-11-06 02:49 PM . Last Modified: ‎2023-05-03 12:26 AM
1163
>>Message imported from previous forum - Category:Scripts and Tips<<
User: dlepeire, originally posted: 2019-04-04 08:12:01 Id:395
Hi everyone,
I've been using ClearSCADA since release release 2010 R2 and now I'm using release 2017 R3.
I've noticed that when I execute an SQL query in ClearSCADA (in a Mimic Script or a Logic Program) or in the QueryPad tool, containing an ORDER BY clause on a field of type string, to sort the results, the sorting order does not look "natural" to me.
Here is an example of the returned resultset for the following SQL query : "SELECT Name FROM CTemplate ORDER BY Name"
Row | Name
0 | 13_test_order_by
1 | 1_test_order_by
2 | 3_test_order_by
3 | Test_order_by
4 | _test_order_by
5 | test_order_by
6 | é_test_order_by
As a French user, I was expecting the following sorting order :
_test_order_by
1_test_order_by
13_test_order_by
3_test_order_by
é_test_order_by
Test_order_by
test_order_by
This is the sorting order that I could get in another database system like SQL Server 2017, configured with a collation "French_CI_AS" (Case Insensitive + Accent Sensitive)
Now I have 2 questions for you guys :
1) Do you know which "collation" is used internally by the SQL engine implemented in ClearSCADA ? To me it looks like the strings in the above example have been sorted **by ascending order of the ASCII code of the first character** of the Name (digits first, then uppercase letters, then underscore, then lowercase letters, then accents)
2) Do you know if there is a way the ClearSCADA server configuration or in the Windows registry to change the way ClearSCADA will sort the strings in an SQL query containing an ORDER BY clause ?
Thanks for your help,
David
  • SCADA
sbeadle
Kirk sbeadle Kirk
Kirk
Reply From User: adamwoodland, posted: 2019-04-05 01:21:59
Hi David,
I don't have an answer to either of your questions, I suspect the answer to the second question is no though.
Independently of any discussions that may happen here, I would recommend you open a ticket with support on this so it can get to the right people to perhaps get an improvement implemented.
sbeadle
Kirk sbeadle Kirk
Kirk
Hi David,
