[Imported] Alarm Redirection on Server Alarms (License primarily)
  • Remote Operations
  • [Imported] Alarm Redirection on Server Alarms (License primarily)
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-11-05 03:01 PM . Last Modified: ‎2023-05-03 12:31 AM
1031
User: du5tin, originally posted: 2018-11-13 22:57:22 Id:318
This seems like it would be a simple thing but I cannot figure out how to effectively redirect the server license expiration alarm. I would like to be able to set its severity to something other than Critical (we use Critical for other process alarms and redirect those to operations) and redirect the System Alarms to a few admins.
What is happening is our client is in a VM environment and is using a network USB device that reboots occasionally. Our CS dongle is in the network USB device and so we lose the license for a time, but the CS server does not pick it up again when the USB unit reboots. We were on a soft license but IT likes to make NIC changes without telling us which is terrible on weekends.
  • SCADA
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-11-05 03:02 PM
Reply From User: adamwoodland, posted: 2018-11-18 22:28:53
It is a text alarm, you couldn't manipulate it in the past and I don't believe anything has changed in the product recently for this.
Alarm redirections need an object to reside against.
Reply From User: BevanWeiss, posted: 2019-01-03 21:55:56
Have you thought about using a loopback adapter? I haven't tried this with the ClearSCADA machine ID stuff, but it's worked recently with Proficy Licensing to get around a NIC MAC changing issue
sbeadle
Kirk sbeadle Kirk
Kirk
