[Imported] 2D Move Animation
  • Remote Operations
  • [Imported] 2D Move Animation
sbeadle
Kirk sbeadle Kirk
318
AndrewScott
Admiral AndrewScott
109
BevanWeiss
Spock BevanWeiss
96
AdamWoodlandToo
Lt. Commander AdamWoodlandToo
39
EcoStruxure™ Geo SCADA Expert
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-11-06 02:54 AM . Last Modified: ‎2023-05-03 12:30 AM
1054
User: Gissit, originally posted: 2018-11-27 08:20:07 Id:327
Hi
Its been a l;ong time since I have been here...
I have just picked up ClearScada after a few years away and I have an application where I need to animate (move) a graphic object in two dimensions. This is actually an overhead view of a gantry crane. It is simple enough to define a path to move in one axis but not so simple for two. I have two objects, one beam and the other the crane cab. When I move the beam on the x axis the cab needs to follow it. The cab moves on hte Y axis.
I'm sure there is a simple solution but I thought I would ask if anyone else has already done this.
  • SCADA
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-11-06 02:55 AM
Reply From User: sbeadle, posted: 2018-11-27 13:11:39
To animate an object's position in two axes, first create an embedded mimic with the thing you want to move, and set a motion path in one direction. Then add parameters for min/max and position. Then on a parent mimic, embed that with suitable parameters and add a motion path to that embedded mimic with its own min/max and position.
Reply From User: Gissit, posted: 2018-11-29 08:24:33
Many thanks, perfectly obvious with hindsight. I am just a little rusty
Would I be correct to assume you are Steve Beadle?
Hi, been a long time. I'm Brian from Alderley, remember me?
Reply From User: sbeadle, posted: 2018-11-29 08:40:29
I do, and it's good to meet you here!
sbeadle
Kirk sbeadle Kirk
Kirk
