How to use web browser to connect to Geo scada server 2020?
  • Remote Operations
  • How to use web browser to connect to Geo scada server 2020?
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
ArunrajPremraj
Ensign ArunrajPremraj Ensign
Ensign
Posted: ‎2022-03-08 04:55 AM . Last Modified: ‎2023-05-02 11:57 PM
1965
I have a clear scada server running in my control room and a client system installed in field. both are in same network, I can ping the server from client machine.
but when i try to access the server by web browser the url failed. what is the issue.
my server  is : 205-OWS-01
ip addres : 192.168.10.65
node: localhost:5481
node cost : 6
In client machine i have configured the server and used this URL " http://192.168.10.65/webx"
the page is not loading.
please guide me , or share me links to configure webX
thank you
  • SCADA
  • ViewX
  • WebX
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2022-03-09 01:54 AM
In response to BevanWeiss
Please contact our support team with your license Site ID at SupportTRSS@se.com and they will be pleased to help.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2022-03-08 08:19 PM
1930
I generally find ping to be worthless when dealing with complex networks.  Firewalls will often allow through ICMP (ping) but will then reject TCP port traffic... so I just start with TCPing now (if I know the TCP port in question)
https://www.elifulkerson.com/projects/tcping.php
If it works, then both firewalls and ping are likely ok.
If it doesn't, then you either have a firewall problem, or a service problem.
You can run TCPing locally on the server to try to rule out the firewall thing (although some firewalls, like Windows, can be configured to even prevent localhost loopback access).
You should check to make sure that you're using the right port.  Port 80 for a SCADA service is a bit unusual.. for s3curity raisons, people like to put it at a non-standard port number, like 8080 / 8443 if SSL encrypt
There are pretty good help docs already available with the Geo SCADA Expert product.  Have a look through them first (including the Installation PDF on the install media).
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
sbeadle
Kirk sbeadle Kirk
Kirk
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
