How to schedule vb script on client
  • Remote Operations
  • How to schedule vb script on client
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
IvanDeMarco97
Lieutenant JG IvanDeMarco97 Lieutenant JG
Lieutenant JG
Posted: ‎2024-01-11 08:15 AM
1665
Hi everyone, I created a script on a mimic that I call with the "Mimic_load" method, is it possible to run this function every minute? The script must run on the client using the "SetRegistry" function.
Thank you!
  • Mimics
  • Scripting
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2024-01-12 02:38 AM
Scripts can only run continuously in the context of a mimic. As soon as the mimic is closed, or a script is run on the same or another mimic, the script is stopped. Scripts should not be used for continuous operations, and as the previous commenter wrote, consider scheduling a task, either server-side using Logic, or client-side using a scheduler or service and a program written in the language of your choice to access Geo SCADA.
Replies 5
_Experimentalist_
Ensign _Experimentalist_
Ensign
Posted: ‎2024-01-12 02:21 AM
That sounds like a task that is probably better served by using Windows Task Scheduler to me.
sbeadle
Kirk sbeadle Kirk
Kirk
IvanDeMarco97
Lieutenant JG
Posted: ‎2024-01-12 06:23 AM
It is unthinkable that all users who connect should create a Task on Windows...
If I have to use the "SetRegistry" function I cannot use the ST logic since it is server-side.
tfranklin
Commander tfranklin
Commander
Posted: ‎2024-01-12 06:30 AM
I think the better angle to take here is to understand what you're trying to accomplish.  There's likely a bad design at play and there's alternative ways to do what you're trying to do.  Steve has some options above that you can consider, but ultimately knowing the specifics would help us guide you on the right path.
geoffpatton
Captain geoffpatton
Captain
Posted: ‎2024-01-12 10:10 AM
Well maybe there is another way to accomplish whatever your end goal is.
If you explain that maybe one of us will have an alternate idea you could try.
