How to Copy or Export data from the Historic List
Select a Country
  • Remote Operations
  • How to Copy or Export data from the Historic List
sbeadle
sbeadle Champion
335
AndrewScott
AndrewScott
125
BevanWeiss
BevanWeiss
103
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
Posted: ‎2022-02-04 02:41 PM . Last Modified: ‎2023-05-02 11:58 PM
8
5606
Newbie here,
How does one copy or export data that is populated when you right click on a point and click "display historic list"? The data I have is exactly what I need, but I cannot use it!! I just want to highlight the whole list and copy it, or have the option to "copy to clipboard" like I can do when I pull up a historic trend. What am I missing??
AndrewScott
AndrewScott
Leader
Posted: ‎2022-02-07 09:39 AM
6
5593
On the Edit tab of the ribbon in ViewX click the Copy button whilst the historic list has focus.
Alternatively, press Ctrl-C keyboard shortcut whilst it has focus.
In both cases the whole list is copied to the clipboard as tab separated text.
Andrew Scott, R&D Principal Technologist, AVEVA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Replies 8
AndrewScott
AndrewScott
Leader
6
5594
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Posted: ‎2022-02-07 10:37 AM
In response to AndrewScott
5585
I knew I was missing something simple! Thank you very much for taking the time to help me out!! Much appreciated
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
sbeadle
sbeadle Champion
Champion
Posted: ‎2022-02-08 02:59 AM
In response to Anonymous user
5567
Just an additional tip. If using Virtual ViewX, you need to ensure the list window has focus, then use the Ctrl-C method. The ribbon method will not appear to work because, for security reasons, the application can only access the clipboard if the browser lets it.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
du5tin
du5tin
Mentor
Posted: ‎2022-03-25 09:53 AM
In response to sbeadle
5512
Is there a way to copy historical or other information from embedded list boxes? Can we use the Ctrl+C method for that? We have customers moving from WebX to Virtual ViewX or standalone ViewX clients and there is a "Copy" command in the bottom right menu on the list boxes in WebX that is not available in ViewX. It would be great to be able to copy data out of an embedded list.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
BevanWeiss
BevanWeiss
Champion
Posted: ‎2022-03-27 03:29 PM
In response to du5tin
It's possibly a 'GeoSCADA Expert Ideas' topic item for the exact implementation you mention.
What we've normally done is have a button that pops out a full query window, using the SQL of the embedded list.
That then allows for copy.  But it's not quite as seamless as just having a copy option on the context menu for the embedded list or a button on the list to directly copy it to the clipboard.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Johnny07
Johnny07
Contributor
Posted: ‎2022-05-10 03:58 AM
5238
Hello, i have another issue regarding to copying data using copy command in Virtual Viewx.
the solution offered here above is working for a small amount of data, when we increase the trend overview to a larger time period, so more data, then Virtual Viewx Crashes after copy command and returns to the logon screen en no data is avaiable on clipboard.
in Viewx we have no issues with the same time frames.
does anybody have the same expierence or a solution for this behaviour?
Greetings,
Johnny Bos
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
BevanWeiss
BevanWeiss
Champion
Posted: ‎2022-05-10 08:21 PM
In response to Johnny07
If you get a crash then you need to go through your local Schneider Tech Support channel to report and investigate this for a fix.
This is a community forum (not an official Schneider Tech Support channel) so bugs etc with the product aren't really addressed here.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Ernestostvo
Ernestostvo
Explorer
Posted: ‎2023-03-31 07:15 AM
I understand your frustration with trying to copy or export data from the historic list in your program. It can be tricky to figure out sometimes.
Have you checked out this blog post on https://blog.coupler.io/how-to-export-data-from-trello/ that explains how to export data from Trello? Even though it's not the same program as the one you're using, the process should be pretty similar and might work for you.
In general, to copy or export data from a list in a program, you usually need to highlight the data you want to copy and then right-click to bring up a menu with the option to copy or export.
