Posted: 2025-10-03 11:41 AM . Last Modified: 2025-10-03 11:47 AM
I’m looking for a supported method to obtain the Object ID values for all tags in our Geo SCADA Expert system.
At the moment, I can only see the ID for a single tag by opening its Status Information window. What I need is a way to pull all tag IDs in bulk. Specifically, I’m asking:
Can Bulk Edit / CSV Export include the Id field for each tag?
Is there a supported SQL query within Geo SCADA (ViewX → Queries) that lists Id, FullName, TypeName for all points?
Is it supported to use the Geo SCADA ODBC/OLE DB provider with an external SQL viewer to export the IDs (read-only)?
If SQL is the right approach, what are the canonical table/column names for accessing object IDs across built-in drivers and modules?
My goal is a simple list or CSV containing at least:
Any official guidance on the recommended approach (Bulk Edit vs. SQL vs. ODBC) would be greatly appreciated.
Thank you,
Posted: 2025-10-03 11:53 AM
In ViewX create a list with the following query:
SELECT Id, Id, FullName, TypeDesc FROM CDBOBJECT ORDER BY FullName ASC
Note the Id field appears twice (lists hide the first occurrence).
Alternative, use the following query in Query Pad:
SELECT Id, FullName, TypeDesc FROM CDBOBJECT ORDER BY FullName ASC
You can also use this second query in Microsoft Excel, Crystal Reports etc. using ODBC or OLE DB.
Posted: 2025-10-03 12:00 PM
THANK YOU SO MUCH!
Posted: 2025-10-14 01:57 AM
Being able to view the Object ID via the Status Information menu appears to be available to those users with configuration rights only. Is this something which can be enabled for all users?
Posted: 2025-10-14 02:09 AM
No, this permission is fixed.
Why would other users need access to this low level information?
