Github GeoSCADA/Driver-SparkplugB Mismatched end-group tag
  • Remote Operations
  • Github GeoSCADA/Driver-SparkplugB Mismatched end-group tag
sbeadle
Kirk sbeadle Kirk
323
AndrewScott
Admiral AndrewScott
118
BevanWeiss
Spock BevanWeiss
100
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
EcoStruxure™ Geo SCADA Expert – Sparkplug B Sample Driver
du5tin
Lt. Commander du5tin
Lt. Commander
Posted: ‎2022-02-01 01:16 PM . Last Modified: ‎2023-05-02 11:59 PM
1333
I am currently attempting to get the open source Sparkplug B DDK driver working. I ran into lots of issues with Nuget packages and the versions therein, I think I have that all sorted now. Really helped to move System.Memory and System.Runtime.CompilerServices.Unsafe to the Geo SCADA install directory.
Currently though I am having trouble with the driver incorrectly interpreting the SP-B message. IN Geo SCADA I am getting an alarm: "Mismatched end-group tag. Started with field x; ended with field y - Alarm raised". It kinda looks like we're getting more or less data than the driver was expecting from the broker.
Publishing edge node is Ignition Edge/MQTT Transmission. Going to try it with a few other publishers to see if things are different with those.
  • Drivers
  • IoT
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
du5tin
Lt. Commander
Posted: ‎2022-02-01 01:32 PM
Turns out I had a bad setting in the Ignition Edge transmitter. It was attempting to send a JSON SP-B package instead of a protobuf binary package. Once I got that changed we were good!
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
du5tin
Lt. Commander
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
