GeoSCADA Expert Mobile application unknown error during connection
  • Remote Operations
  • GeoSCADA Expert Mobile application unknown error during connection
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
115
BevanWeiss
Spock BevanWeiss
98
  • Remote Operations Forum
Antonio_Sgalla
Crewman Antonio_Sgalla
Crewman
Posted: ‎2025-07-28 01:02 AM . Last Modified: ‎2025-08-28 03:45 AM
342
Good morning, I installed and licensed successfully the GeoSCADA Expert Mobile Server, but when I try to access it from my mobile app I get "Unknown Error" as in the following screeshot.
My device is authorized in the Mobile Server Configurator and when I read the IIS logs I can see it returns the "404 not found" error code.
Could you help me with my problem, please?
  • ViewX
  • connection
  • error
  • expert
  • geoscada
  • mobile
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2025-07-29 03:21 AM
321
Hi Antonio,
you may need help from the Support team here.
You are correct to check the IIS logs. An initial connection from a mobile device will look like:
2025-07-29 10:11:53 192.168.1.29 GET /mobile/service.svc/v1/admin/device/pin - 443 - <address> Dalvik/2.1.0+(Linux;+U;+Android+12;+SM-M315F+Build/SP1A.210812.016) - 200 0 0 126
2025-07-29 10:11:53 192.168.1.29 GET /mobile/service.svc/v1/admin/servers - 443 - <address> Dalvik/2.1.0+(Linux;+U;+Android+12;+SM-M315F+Build/SP1A.210812.016) - 200 0 0 13
2025-07-29 10:11:55 192.168.1.29 GET /mobile/service.svc/v1/LOCAL/token - 443 - <address> Dalvik/2.1.0+(Linux;+U;+Android+12;+SM-M315F+Build/SP1A.210812.016) - 200 0 0 507
You can use a web browser to check the web connection by using the URL:
https://<address/name>/mobile/service.svc/v1/admin/pin
This will return True.
Check that the MOBILECOMPANION service is running, and (in IIS config) that the web server attached to the port is 'ClearSCADAMobile'.
Antonio_Sgalla
Crewman
Posted: ‎2025-08-04 01:03 AM
In response to sbeadle
Good morning!
When I connect to "https://<SERVER IP>/mobile/service.svc/v1/admin/pin" I get "Secure connection failed"
I'm in contact with the Support Team, thank you.
Best regards,
Antonio.
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2025-08-05 01:37 AM
I'm sure they can help, but looks like a certificate issue.
