Posted: 2025-07-29 11:20 PM
Firstly I want to reference this thread from 2023 which mentions Copy to Clipboard becoming available to GS2023:
However, on our GS2023 system, embedded lists only have the Copy to File option available. Selecting a row on an embedded list and pressing Ctrl-C does not copy the entire list to clipboard. On the other hand, when opening the same query in its own window, Ctrl-C does copy to clipboard.
Is it possible to replicate this same Virtual ViewX Ctrl-C behaviour to embedded lists?
Posted: 2025-08-05 01:35 AM
"if you could select/highlight rows on multiple embedded lists on the same page." - yes, you can.
"create a pick action to 'open' the embedded list as a hidden popup, operate the copy action and then close it?" - I don't think so.
You can add a button, menu or list pick action which says 'Copy' and run a script which reads the active query and copies its data to the clipboard. In the past I used this - works on my PC.
'Copy to clipboard
Private Sub WriteClip( Text)
Dim objIE
Set objIE = CreateObject("InternetExplorer.Application")
objIE.Navigate("about:blank")
objIE.document.parentwindow.clipboardData.SetData "text", Text
objIE.Quit
End Sub
Posted: 2025-08-01 01:02 AM
I recall that keyboard focus and having multiple lists on one mimic are complications which prevent this from being added.
Steve
Posted: 2025-08-04 07:37 PM
Thanks Steve
I was hoping that selecting a row in the embedded list might be a way to indicate where the keyboard focus was but don't remember if you could select/highlight rows on multiple embedded lists on the same page.
I wonder if there is a way to create a pick action to 'open' the embedded list as a hidden popup, operate the copy action and then close it? I could probably script that as a work-around, but maybe there's a way to implement this as a product feature?
'Copy to clipboard
Dim objIE
objIE.Quit
End Sub
Posted: 2025-08-06 04:51 PM
Thanks, will give this a go
