Geo Scada Expert Installation on Windows 11, IIS ARR Error, Local Web Server Proxy 1 by 2 IIS Issue
  • Remote Operations
  • Geo Scada Expert Installation on Windows 11, IIS ARR Error, Local Web Server Proxy 1 by 2 IIS Issue
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
Waleed1
Crewman Waleed1
Crewman
Posted: ‎2023-11-17 02:50 AM
1550
I am new to SCADA systems and learning. I was trying to install Geo Scada Expert 2022 on Windows 11 Build 22621. During the installation process, it asks for the following requirements
  • Required for Geo SCADA Server Local Web Proxy Part 1 by 2 IIS
  • Required for Geo SCADA Server Local Web Proxy Part 1 by 2 ARR
If we proceed with this default setting the following error arises and installation aborted.
  • The following required features are not available on your system, IIS Digest Authentication, IIS IIS Certificate Mapping Authentication, IIS Client Certificate Mapping Authentication, IIS Windows Authentication, IIS Cert Provider
  • There was an error during the Windows features configuration process. Your original configuration will be restored.
If the first two requirements are unselected, installation is successful.
  • Service Manager is running
  • ViewX is also running with a communication problem
  • Status
  • Server configuration is empty
  • Server Status
Please help me to resolve this issue. I tried to resolve it with Google's help by enabling IIS in Windows 11 and enabling authentication as required per error but nothing changed.
  • Thank you everyone for responding
  • arr
  • geascadaexpert2022
  • iis
  • proxy
  • server
  • win11
JChamberlain1
Lieutenant JG JChamberlain1
Lieutenant JG
Posted: ‎2023-11-21 10:17 PM
First issue is likely the Windows 11 edition you're running, is it Home or Pro/Enterprise? Home isn't supported.
Your second issue is that you've chosen an install option without the local connection pre-configured; you'll need to run the Configure Connections tool and add a connection to the server.
