Find the Last Position of a Character in a string
  • Remote Operations
  • Find the Last Position of a Character in a string
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
115
BevanWeiss
Spock BevanWeiss
98
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
Tanquen
Lt. Commander Tanquen
Lt. Commander
Posted: ‎2020-10-07 12:10 PM . Last Modified: ‎2023-05-03 12:09 AM
2709
Trying to create a text animation expression that will give me all the characters after the last occurrence of a Space or particular character.
I've seen examples online that use in string reverse, Find, Trim and other commands that don't seem to be available. I think I've only got InString, Left, Mid, Right, Len etc.
I've tried nesting some Mid commands and it works but it's getting ugly fast.
MID( MID( MID( ".Name", INSTRING( ".Name", ' ' ),-1 ), INSTRING( MID( ".Name", INSTRING( ".Name", ' ' ),-1 ), ' ' ),-1 ), INSTRING( MID( MID( ".Name", INSTRING( ".Name", ' ' ),-1 ), INSTRING( MID( ".Name", INSTRING( ".Name", ' ' ),-1 ), ' ' ),-1 ), ' ' ),-1 )
Using the Right command also works but seems a little fragile. If there was an extra space in the last seven characters and or the end of the string that I want at some point is greater than seven characters it'll stop working.
MID( RIGHT( ".Name",7), INSTRING(RIGHT( ".Name",7), ' '), -1 )
  • Scripting
  • ViewX
  • scada
  • SCADA app
  • SCADA control
  • SCADA data
  • SCADA integration
  • SCADA network
  • SCADA programming
  • SCADA software
  • scada system
  • SCADA tutorial
  • SCADA web application
  • Telemetry and SCADA
AdamWoodland
AdamWoodland Schneider Alumni (Retired)
Posted: ‎2020-10-07 02:40 PM
2702
Check out ELEMENT(), specify a space as the splitter, index of 0 (or 1, can't remember which is the first index) and specify in reverse (i.e. last param is 1).
See the help for all the options on ELEMENT()
  • scada
  • SCADA app
  • SCADA control
  • SCADA data
  • SCADA integration
  • SCADA network
  • SCADA programming
  • SCADA software
  • scada system
  • SCADA tutorial
AdamWoodland
2703
  • scada
  • SCADA app
  • SCADA control
  • SCADA data
  • SCADA integration
  • SCADA network
  • SCADA programming
  • SCADA software
  • scada system
  • SCADA tutorial
Tanquen
Lt. Commander
Posted: ‎2020-10-07 03:08 PM
In response to AdamWoodland
2697
Thanks!
That is much better. Too bad it's not on the same page in the manual as the String Functions.
This works:
ELEMENT(1, ' ', ".Name", 1)
I had to search for "Element (" with quotes to find it.
  • scada
  • SCADA app
  • SCADA control
  • SCADA data
  • SCADA integration
  • SCADA network
  • SCADA programming
  • SCADA software
  • scada system
  • SCADA tutorial
Tanquen
Lt. Commander
Posted: ‎2020-10-22 09:22 AM . Last Modified: ‎2020-10-30 11:00 AM
In response to Tanquen
Sort of on the same topic, is there a command that's the opposite of STR? I'm having some issues with parameter values not being processed by the expression in a way I'd expect. I have an object in the template that's looking at a parameter for its visibility and that works but if I take the same parameter and the visibility is a expression flowchart it no longer works unless I say parameter: tag1 =’1’. I can also get around it by saying “parameter: tag1 OR parameter: tag2”. But I can't use a flow chart expression to check if tag one is true and then if tag two is true and so on. I'm thinking it's because when I use the flowchart expression it's seeing the "parameter: tag1" as a string and not a value.
Looks like INT works.
INT(INTEGER or REAL)
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
