Filtering out Alarm List using SCRIPT in ClearSCADA
  • Remote Operations
  • Filtering out Alarm List using SCRIPT in ClearSCADA
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
mhayat
Ensign mhayat
Ensign
Posted: ‎2021-03-09 10:52 AM . Last Modified: ‎2023-05-03 12:05 AM
2285
Hi All,
Can anybody help me with this:
I need to apply filtering on Alarm List using some kind of script. What i am trying to achieve here, i have a filter script which i use to filter out some wells on a normal list but i am looking to add a functionality which will look at the Alarm list at the same time and filtered out the alarms only associated with the filtered wells.
In short how can i edit the filter functionality using script in Alarm list.
  • Mimics
  • SCADA
  • Scripting
  • ViewX
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2021-03-09 01:40 PM
2278
It's possible to change the Animation properties on mimic objects during runtime.
It can get a little tricky however...
Essentially there is a bit of a hierarchy: Mimic -> Layers -> Items -> Properties (inc animations)
So if you know the layer name, and the alarm list name, you should be able to access it via
Mimic.Layers("LAYER_NAME").Items("ITEM_NAME").Filter = "*"
And then the Filter property should align with what is required.  I don't remember the exact setup for the Alarm List filters, I can't recall if it's actually a collection, in which case you'd need to do things like call .Add(), .Clear() those kind of Collection methods on it, or whether it is just a delimited string.  You could MsgBox the current value of it and get some info on this.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
BevanWeiss
Spock BevanWeiss
Spock
2279
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
mhayat
Ensign mhayat
Ensign
Posted: ‎2021-05-01 07:02 PM
In response to BevanWeiss
Thank you it worked for me.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
