Posted: 2024-06-29 12:25 AM
I have installed geo Scada expert 2022 (build 85.8544) May 2023 update. When I am exporting file, it is not exporting in sde format.
It is showing export successfully but not getting save in sde format.
Posted: 2024-07-01 04:29 AM
ViewX is saving the file without the ".sde" file extension. You can workaround this issue by renaming the file to add the missing extension. You may also be able to workaround this issue by disabling the Windows "Hide extensions for known file types" feature.
This bug was fixed in the Geo SCADA 2022 July 2023 update (6.85.8608) onward.
Posted: 2024-07-16 09:51 PM
@AndrewScott Yes later i downloaded Geo SCADA 2022 July 2023 update (6.85.8608) and the issue was solved.
Thank you sir for support.
