Custom configuration fields
  • Remote Operations
  • Custom configuration fields
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
Posted: ‎2022-05-31 11:22 PM . Last Modified: ‎2023-05-02 11:56 PM
1082
How can I add a name for custom configuration field? I can't find anything about it in manual
  • ViewX
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2022-06-01 02:08 AM
Metadata fields have names declared on the dialog box where you create them.
To see a 'name' as a description field on a configuration form, click the Labels tab.
See:
https://tprojects.schneider-electric.com/GeoSCADAHelp/Geo%20SCADA%202020/Default.htm#ServerAdministr...
Fields:
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
AndrewScott
Admiral AndrewScott
Admiral
Posted: ‎2022-06-01 04:27 AM
If you are referring to the "Display Name" for a custom field then this can't be set using the UI in ViewX, but can be set by manually modifying the "ClearSCADAMetadata.xml" file on each server. The server will need to be restarted after changing the file.
See https://tprojects.schneider-electric.com/GeoSCADAHelp/Geo%20SCADA%202020/Default.htm#ServerAdministr...  to find the location of the metadata file.
In the XML file the Field element has a displayName attribute, for example:
<Table name="CGroup">
<Field stream="Config" displayName="Software Level 1" description="" type="String" length="129" row="5" column="2" rowCount="1" opcProp="0360E02F" writePrivilege="CFG" extraFieldType="SearchKey">swLevel1</Field>
</Table>
Andrew Scott, R&D Principal Technologist, AVEVA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
