Crystal report Generate Fault
Select a Country
  • Remote Operations
  • Crystal report Generate Fault
sbeadle
sbeadle Champion
337
AndrewScott
AndrewScott
128
BevanWeiss
BevanWeiss
104
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
aed
aed
Explorer
Posted: ‎2022-08-25 06:54 AM . Last Modified: ‎2023-05-02 11:53 PM
1403
I am taking Driver offline error when I had generated crystal report. I can't generate at GEOSCADA. I tried to restart SQL export and Crystal report driver. But still they are not working Could you support please?
Tags
  • SCADA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
AndrewScott
AndrewScott
Leader
Posted: ‎2022-08-25 07:04 AM
1400
The screenshots are a little too small to read but it looks like the drivers aren't running. You need to look in the driver log files to find out why they aren't running.
Both these drivers use the same Windows user account (the printing user, see System Administration > Server Administration > Printer Settings) so it may be the Windows user name/password are invalid or incorrect.
Andrew Scott, R&D Principal Technologist, AVEVA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
aed
aed
Explorer
Posted: ‎2022-08-25 11:33 PM
In response to AndrewScott
1370
Thank you. Driver is running. But I can't generate. there is a different error. On the Crystal reports design screen, I can draw the data with ODBC and make a print view. However, when I press the generate button in Geo SCADA, it gives the following error and does not generate. Below are the settings I made.An also when I chose report user to "emre" user. I can't login with that  user at Geoscada.  What's the problem?
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
AndrewScott
AndrewScott
Leader
Posted: ‎2022-08-26 01:55 AM
In response to aed
The "Failed to open the connection" error from Crystal Reports is usually due to the ODBC DSN used by the Crystal Reports driver not being setup correctly (on the main server). It either doesn't exist, has the wrong name or is misconfigured (e.g. bad credentials). See Driver Reference > Crystal Reports Driver > Configuring Crystal Reports Server Settings in online help for more details on how to setup DSN.
You can't log on as user "emre" as the "Report User" option is enabled. Report users can only logon via ODBC, see "System Administration > Security > User Accounts > Define Whether a User Account is Used for Report Generation" section in the online help.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
