Crystal Report Timezone Problem
  • Remote Operations
  • Crystal Report Timezone Problem
sbeadle
Kirk sbeadle Kirk
323
AndrewScott
Admiral AndrewScott
118
BevanWeiss
Spock BevanWeiss
100
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
abdullah123456789
Lt. Commander abdullah123456789
Lt. Commander
Posted: ‎2022-11-04 05:03 AM . Last Modified: ‎2023-05-02 11:51 PM
1141
I'm using Crystal Report for reporting in Geo SCADA. When i generate any report, it's created a report in the time i want and have a problem in this situation: I also using SQL Query for report and these datas get correctly. (My local time is GMT +3). But in Crystal Report the same datas have different time, it arrives 3 hours ahead of my local time. I tried the "ShiftDateTime" command but nothing happened. Is the solution of this problem command or anything else? I'm sharing two screenshot about the same day.
This screenshot is Crystal Report format. The first data is 225.34 on 1st August at 12 A.M. Later 214.62, 210.39, 195.02...
This screenshot is the format by using SQL Query. The first data is 225.34 on 31th July at 9 P.M. Later 214.62, 210.39, 195.02...
I need to your help.
  • SCADA
  • ViewX
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
AndrewScott
Admiral AndrewScott
Admiral
Posted: ‎2022-11-04 05:52 AM
Have you checked the "Local time" option in the ODBC data source that you are using for the Crystal Reports? If you haven't the server will return times in UTC.
See Configure the ODBC DSN Settings for details.
Andrew Scott, R&D Principal Technologist, AVEVA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
