Posted: 2021-06-14 03:56 AM . Last Modified: 2023-05-03 12:02 AM
ClearSCADA License run time
Is there any way to display the remaining run time available in the current session before the DB server goes off? I am using a valid license with 12 hr run time. After that, the DB server stops, and I have to manually start the DB server. It will be helpful if can know beforehand how much time is remaining.
Thanks in Advance
Posted: 2021-06-15 06:34 AM
I don't believe licence items like that are exposed within the GeoSCADA Expert database. You could raise it as a feature request in the Idea forum of this portal.
I'm pretty sure if you display the licence information for the server it advises how much time is remaining, but this is still outside of the database itself. You could probably use the .NET API to retrieve this information programmatically, and if desired push it back into a database object (like a point or a variable).. you could create a driver to do this in a more integrated manner. But it does seem like quite a lot of work just to get the licence info... so I'd start with the feature request.
Posted: 2021-06-15 10:00 AM
Thanks for the response BevanWeiss
I appreciate the solution. As a workaround, I am trying to get the info using .NET API. I will surely raise this as a feature update.
