Posted: 2024-04-15 06:57 AM
Hi, I would like to find out which node is the main server. I wrote this code but the state (by monitor.GetNodeState) is always null:
static void Main(string[] args)
var credentials = new NetworkCredential("myusername", "mypw");
ServerNode mainNode;
ServerSystemCollection systems = new ServerSystemCollection();
using (XmlReader reader = XmlReader.Create(@"\\geoscadaweb\c$\ProgramData\Schneider Electric\ClearSCADA\Systems.xml"))
systems = new ServerSystemCollection(reader);
ServerSystem system = systems["GEOSCADA"];
ServerSystemMonitor monitor = new ServerSystemMonitor(system);
monitor.Start(false);
monitor.SetProvisionalLogOnCredentials(credentials.UserName, credentials.SecurePassword);
foreach (var node in system.Nodes)
var state = monitor.GetNodeState(node);
if (state != null && state.State == ServerState.Main)
mainNode = node;
break;
monitor.Stop();
Posted: 2024-04-18 02:30 AM
I suggest you look this up in the Object Browser for the .Net API:
ClearScada.Client.ServerStateDetails GetServerState()
Member of ClearScada.Client.Advanced.IServer
Summary:
Gets the current state of the server.
Returns:
The current server state.
Summary:
Returns:
Posted: 2024-04-18 10:20 PM
Thank you Sbeadle! It works! It's fantastic!
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using ClearScada.Client;
using ClearScada.Client.Simple;
using System.Security;
using System.Net;
using System.Xml;
var credentials = new NetworkCredential("myUser", "myPWD");
Connection conn = new Connection("TestApp");
if (node != null && !node.IsWebserver)
ServerNode serverNode = new ClearScada.Client.ServerNode(node.HostName, node.Port);
conn.Connect(serverNode);
var state = conn.Server.GetServerState();
mainNode = node;
break;
conn.Disconnect();
//Connected with main Server
Posted: 2024-04-28 03:17 PM
And thank you for providing example code for the next person to use!
Posted: 2024-05-01 02:42 AM
You are welcome! That's the goal of a community! 😁
