Check number of configured heads in mimic script
  • Remote Operations
  • Check number of configured heads in mimic script
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
rlao
Lt. Commander rlao
Lt. Commander
Posted: ‎2020-05-19 07:49 PM . Last Modified: ‎2023-05-03 12:14 AM
1576
I have a navigation script that is failing on a particular ViewX client because the script is calling App.OpenWindowOnHead on Head 3, but that particular client only has 2 heads configured (one less monitor than all the other clients).
I'm trying to get around it by getting the script to return the max number of heads configured on the client and fall back to using that max number if the desired head number is greater than it.
I thought it would be a simple thing to do but I cannot find such a function at all in the help files.
Can what I proposed be done or is there another way to get around this issue?
  • Mimics
  • SCADA
  • Scripting
geoffpatton
Captain geoffpatton
Captain
Posted: ‎2020-05-20 06:23 AM
This should do it
On Error Resume Next
OpenOnHead3
If Err.Number <> 0 Then
OpenOnHead2
End IF
geoffpatton
Captain geoffpatton
Captain
This should do it
OpenOnHead3
OpenOnHead2
End IF
