Posted: 2021-07-12 02:54 AM . Last Modified: 2023-05-03 12:02 AM
Hi, is it possible to load a data file in to the history of a point with c#. I have an example of loading a data value.
Posted: 2021-07-12 09:18 AM . Last Modified: 2021-07-12 09:23 AM
The more you know. Thx
Looks like reason is still defaulted to 0 though.
Depending on the use case you may still consider LoadDataValues for the extra reason code parameter.
*Edited -- I RTFM*
Posted: 2021-07-12 07:06 AM
It should be the same process but calling a different method.
I'd reference this article here, but keep in mind that the Resource Center is going away.
The below is shamelessly copied from the article above.
LoadDataFile
LoadDataFile( FileName{String} )The LoadDataFile method takes a filename as its single parameter. This is the name of a local CSV on the main server. Some points to note about the files to be imported:
Posted: 2021-07-12 09:12 AM
The online help has two examples of using the LoadDataFile method, plus details of how to specify quality:
See https://tprojects.schneider-electric.com/GeoSCADAHelp/Geo%20SCADA%202020/Default.htm#ServerAdministr... (bottom of page)
*Edited -- I RTFM*
Posted: 2021-07-12 09:24 AM . Last Modified: 2021-07-13 01:50 AM
The 'reason for logging' for each record is fixed as "Current Data" (0) when using LoadDataFile method.
Posted: 2021-07-12 03:10 PM
Hi, yes the line below is exactly one of things I was trying to determine.
Is there a big time saving with LoadDataFile to make it worth while investing the extra time and effort as to using LoadDataValues.
I already have code that iterates through with LoadDataValues.
"Depending on the use case you may still consider LoadDataValues for the extra reason code parameter"
I would still like to see the LoadDataFile work with C#.
But maybe at a later date.
Posted: 2021-07-16 08:36 PM
There were performance benefits, I think when I last did anything with the LoadDataFile it was on the order of 2-10x faster.
But the restrictions, and the requirement to generate the file in a particular format really meant that it wasn't worth it.
The overall process needed more steps, and hence it actually took longer in real world times.
Issues were things like:
I'd say if LoadDataValues is working for you, it's easiest to just keep that as the backend load mechanism, and then you can easily tweak your front end loading code to do the things you want (like loading data from the client etc)
