Adding a new column or transition table to CDBHistoric
  • Remote Operations
  • Adding a new column or transition table to CDBHistoric
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
bamador
Ensign bamador
Ensign
Posted: ‎2022-04-12 11:26 AM . Last Modified: ‎2023-05-02 11:57 PM
1128
Hello Everyone,
I need to see the best way to add a way to track a tag or batch identifier for our internal use. But connect that to the historic record in CDBHistoric table.
I was leaning towards a creating a transition table (Data Table Object) with my custom column (tag/batch), and link that to the record id within CDBHistoric. I worry that will cause a major slow down to the CDBHistoric performance when joining.
Is there any better ideas or tips anyone could advise me on.
Best Regards,
Brandon
  • SCADA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2022-04-12 03:36 PM
1116
I think it will be tricky.  I've never tried it myself, but I think you would need to add a time constraint to the CDHistoric query also.
I think if you just try to query it (as either a top level or sub query reference) only tying it to the RecordId then I think it will return an error of an 'Unconstrained Historic Query'.
As such you would need to have an idea of what time range that RecordID would exist within, so you'd probably want to use the timestamp IN ADDITION to the RecordId.  So you could do:
SELECT xxxx
FROM DataTable T
LEFT OUTER JOIN CDBHistoric H
  ON H.TimeStamp = T.TimeStamp
  AND H.RecordId = T.HisRecordId
Adding such a record per historic entry would be quite expensive in regards to disk space (and disk IO).
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
bamador
Ensign bamador
Ensign
Posted: ‎2022-04-15 01:50 PM
In response to BevanWeiss
@BevanWeiss Thanks for the reply, agree on your suggestions. I'm worried as well it will expensive on drive space. I would plan on using timestamp/recordTime as well if needed. Worried still about the performance cost while that additional custom data table grows, while fetching data.
Thanks for your thoughts.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
