Posted: 2025-02-18 01:02 AM
Adding a Region to a Point
I have a question about Geo Scada Expert 2023, which is the August 2024 version. I used Geo Scada Expert 2021 before and this was the February 2022 version. I think some new features have been added between these two versions and one of them is about Region definition. Previously, I could mark that location on the map according to the location information I assigned to the instance, but this was only in a point form, I was not defining any region, I show it on the map as follows
In the documents I reviewed, definitions can be made in the form of a circle, rectangle or polygon. I could not fully understand how to do this part. I created a new Region and made the following adjustments in it.
I added these to the Map Set.
The Query I used is as follows.
What should I do for the point I shared in the first image and whose location is marked to also represent a region? The marked point will sometimes be in the center of the region and sometimes in other locations. Do I need to define an additional Locaiton value in the Region settings to define this region? Or do I need to make a change on the Query? I am waiting for your help on this matter. Thank you in advance.
Posted: 2025-03-06 01:25 AM
See the section in Geo SCADA 2022 Release Notes:
In Mapping Enhancements there is a description of how to add a Region to a map, and how to configure the region outline.
Note that display of regions is restricted to GeoJSON polygon outlines.
Posted: 2025-02-24 06:03 AM
I can't see any of your images.
Anyway, a point/object is in a region if it's co-ordinates are within the bounds of the region. All you need to do is enter it's geo location on the configuration form of the object.
Posted: 2025-03-04 06:25 AM
This was one of the images I added before. I could display it like this in previous versions, and now I can display it like this when I make the necessary adjustments. However, when I try to do it the way you said, a region is not defined around this point. For this, I added a Region, and entered a radius value of 1000 meters to center this point. Do I need to add something extra to the SQL query?
The query I use for this place is as follows:
SELECT
FULLNAME, GISLOCATION->LATITUDE, GISLOCATION->LONGITUDE, GISLOCATIONSOURCE,
CASE
WHEN GEOPOSITION IN (SELECT CDBPOINTSOURCE.GEOPOSITION FROM CDBPOINTSOURCE WHERE CDBPOINTSOURCE.QUALITY < 192) THEN 255
WHEN GEOPOSITION IN (SELECT CDBPOINTSOURCE.GEOPOSITION FROM CDBPOINTSOURCE WHERE CDBPOINTSOURCE.QUALITY = 192) THEN 0 END AS FOREGROUND,
CASE
WHEN GEOPOSITION IN (SELECT CDBPOINTSOURCE.GEOPOSITION FROM CDBPOINTSOURCE WHERE CDBPOINTSOURCE.QUALITY < 20) THEN 255 END AS BLINK
FROM
CGROUP
WHERE
Station_Type = 1
The configurations in MapSource are like this.
Posted: 2025-03-04 09:50 PM
When I add the coordinates of a point, I can see the location on the map as shown in the image. This was also the case in the old versions I used. However, even if I entered the coordinate information as you said, it was not possible to mark this point as a region. For this, I added a new Region. Then, I selected the Circle type for the Region and entered the same coordinates as the point I showed on the map and 1000 as the radius value. I defined this Region I created in the MapSet configuration with Layer and Query. But I could not display any region in this state.
I used the template-instance structure. Here, I tried the configuration separately in the template and in the instance for the Region.
I used an SQL query while showing it as a point on the map. Do I need to update the query to be able to display the Region? The query I currently use is as follows.
Posted: 2025-03-06 12:59 AM
I can't see your images. They come through as triangles.
Can you see this one?
Posted: 2025-03-19 01:41 AM
I think there is a problem with uploading images on my side. I can see the image you sent. In addition to this topic, I would like to ask something like this. Is it possible to import these regions as a .shp shapefile file in order to view them in GeoScada? Do I have to create a region from within GeoScada for this process?
Posted: 2025-03-20 01:03 AM
The format is GeoJSON.
The 2022 release notes explain the process of creating these.
https://www.se.com/us/en/download/document/Geo_SCADA_2022_RelNotes_202411/
You can use this web site to create them:
Posted: 2025-03-20 01:46 AM
Hello ,I have a question about GeoJSON polygon outlines.Is there any limitations of point count in polygon? I have too many points in Areas. How can I add this area or How can I increase point count ?
This is the error warning I received when i tried to add more then one area .
Posted: 2025-03-21 02:57 AM
Yet again the images don't get displayed. I have asked Forum Admins about this. How are you adding them?
There will be a size limitation on the points in the Region - to limit mem use and prevent performance issues.
Posted: 2025-04-02 11:24 PM
Hello, I am adding the images by dragging and dropping. What is the size limitation?
How many points can I add to the region?
Posted: 2025-04-04 01:37 AM
Maybe the image issue is due to the file type?
Region size is limited by the size of the GeoJSON text - about 16Kb
