API for python connections
  • Remote Operations
  • API for python connections
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
hcruz
Crewman hcruz
Crewman
Posted: ‎2024-10-15 10:06 AM
659
hello community.
is it possible to use python to write on Scada through API but not connected locally to the Scada?
  • SCADA
AdamWoodlandToo
Lt. Commander AdamWoodlandToo
Lt. Commander
Posted: ‎2024-10-16 08:45 PM
You can use the Geo SCADA Client .NET API from any machine with the Geo SCADA client components installed, it doesn't need to be the server itself.
If you want to do this without any dependencies, you could use the SOAP interface, although its not as clean as the .NET API.
If you need example Python code, see Steve's comment at https://community.se.com/t5/EcoStruxure-Geo-SCADA-Expert/how-to-connect-to-geoscada-database-from-py...
AdamWoodlandToo
Lt. Commander
