Fastest way to assign several devices to a usage at once
EcoStruxure Energy Hub
This forum is dedicated to supporting EcoStruxure Energy Hub service providers and partners with system implementation, reporting skills growth, and in demonstrating profitable improvements in monitored sites. Ask questions, get expert answers and the latest offer news, provide feedback and share community experience and knowledge!
  • EcoStruxure Power & Grid
  • EcoStruxure Energy Hub
  • Fastest way to assign several devices to a usage at once
Thierry_Baudard
Commander Thierry_Baudard Commander
8
EduardoFainblum
Commander EduardoFainblum Commander
6
Mathew_Losey
Lt. Commander Mathew_Losey Lt. Commander
5
Back to EcoStruxure Energy Hub
Posted: ‎2022-04-27 06:40 AM . Last Modified: ‎2023-03-01 02:15 PM
853
I am configuring a site for the ECC module with many devices and I want to assign several devices to a usage.
I don't want to drag them out one at a time, is there a faster way to configure several devices at once?
Thanks in advance.
Anthony
  • Tips and Tricks
David_Chapman
Commander David_Chapman Commander
Commander
Posted: ‎2022-04-28 01:13 PM
Hi, you have a couple options in the Energy hierarchy to select multiple devices for assignment or reassignment at once.
1) If the devices you want to assign are in a continuous sequence in the list you can multi select any number of devices in the list of devices by clicking on the first device in sequence then shift clicking on the last device in sequence. This will select all of the devices between the first and last click.
2) If the devices are not in sequence, you can hold ctrl then click any number of devices to pick a group of devices to assign.
3) If you are re-assigning already placed devices you can hold shift and click to draw a fence around the devices you want to select. Once selected you can move them in a group to a new usage.
David_Chapman
Commander
