Start HMI & Popup
EcoStruxure Automation Expert / IEC 61499 Forum
Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
  • Industrial Automation
  • EcoStruxure Automation Expert / IEC 61499 Forum
  • Start HMI & Popup
mohamedriswan
Ensign mohamedriswan Ensign
6
JeromePetit
Ensign JeromePetit Ensign
4
KarimBenameur
Ensign KarimBenameur Ensign
4
EcoStruxure™ Automation Expert
Back to EcoStruxure Automation Expert / IEC 61499 Forum
DP-JYC
Lieutenant JG DP-JYC
Lieutenant JG
Posted: ‎2021-11-12 07:22 AM . Last Modified: ‎2023-07-28 02:23 AM
3516
Start HMI & Popup
I'm using EcoStruxure Automation Expert a lot.
  • For libraries development
  • For system development
And each time I start my HMI, I get this popup:
And it's really annoying... especially in development where you restart your HMI all the time!
In all my systems I have many devices (because I'm distributing my application 😉) but I don't necessarily need all of them to work.
In some cases, I have designed my system with 2 resolutions the first one will need Data of controller 1, 2 and 3 and the second one data of controller 4, 5 and 6. So by design, I know that I will NEVER communicate with all devices... But I still get an "Error" popup that I need to close all the time.
One great feature of the HMI is that symbols turns pink when there is an issue with some data. At this time, people will check communications with devices.
Could you remove this popup?
Thx in advance!
CGG43
Crewman CGG43 Crewman
Crewman
Posted: ‎2022-01-21 02:36 AM
In response to DP-JYC
3318
This issue is fixed and will be delivered along with V21.2 U1.
This popup won't appear anymore.
Replies 6
CGG43
Crewman
Posted: ‎2021-11-15 12:52 AM
5
3501
Hello @DP-JYC , I'll have a look to it.
DP-JYC
Lieutenant JG
Posted: ‎2021-12-20 10:31 AM
In response to CGG43
3404
Hi @CGG43
Any update?
CGG43
Crewman
Posted: ‎2021-12-21 02:44 AM
3390
Still working on it.
The message provides some information, but does not require a dedicated popu tha tyou have to acknowledge.
I would propose then to transform it into one or several (one per device) messages, such as fr example Error/Warning message in the Log.
What do you think?
DP-JYC
Lieutenant JG
Posted: ‎2021-12-21 02:55 AM
3388
Thx for the update.
First of all, it's definitely not an "Error".
Then, pressing on "F1" will give you the diag, I don't see the need of something else.
When you speak about
You refer to the IDE, right? But here I'm talking about the operation phase, when the HMI starts and connect (or not) to devices.
I would  simply remove this popup and that's it.
CGG43
Crewman
3319
DP-JYC
Lieutenant JG
Posted: ‎2022-01-21 03:07 AM
Great news. Thx
