Automation Expert Asset Link : Bulk Engineering
EcoStruxure Automation Expert / IEC 61499 Forum
Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
  • Industrial Automation
  • EcoStruxure Automation Expert / IEC 61499 Forum
  • Automation Expert Asset Link : Bulk Engineering
mohamedriswan
Ensign mohamedriswan Ensign
6
KarimBenameur
Ensign KarimBenameur Ensign
4
EcoStruxure™ Automation Expert
Back to EcoStruxure Automation Expert / IEC 61499 Forum
anandbpillai
Ensign anandbpillai Ensign
Ensign
Posted: ‎2021-12-20 10:00 AM . Last Modified: ‎2023-07-28 02:23 AM
2691
Where can we find more details for the EAE 21.2 Asset Link : Bulk Engineering.
Any reference or procedures to follow.
SameerK
Ensign SameerK Ensign
Ensign
Posted: ‎2022-01-04 10:27 PM
Hello @anandbpillai ,  Automation Expert Asset Link : Bulk Engineering helps bulk generate CAT instances from Engineering Input sources like AVEVA Engineering (when online access is available) or DEXPI (ISO15926 standard based format for offline exchange of engineering data).
Best place to understand procedure to configure connection with AVEVA Engineering and use this functionality within Automation Expert is to g through the user guide - simply search for Bulk Engineering in user guide search tab or navigate to following section using contents:
EcoStruxure Automation Expert User Manual
=>EcoStruxure Automation Expert Build Time User Environment
==> EcoStruxure Automation Expert Data Functions
===> AssetLink for Bulk Engineering
If you have any specific queries or need quick demo, will be happy to arrange the same as well.
TomRos
TomRos Schneider Alumni (Retired)
Posted: ‎2021-12-23 09:58 AM
Hi @anandbpillai, thanks for the question.  Most of the team is out of the office on holiday at the moment, but I'll be sure we follow up in the first week of January.
SameerK
Ensign
