SoftdPAC v23.1 on Raspberry pi
EcoStruxure Automation Expert / IEC 61499 Forum
Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
  • Industrial Automation
  • EcoStruxure Automation Expert / IEC 61499 Forum
  • SoftdPAC v23.1 on Raspberry pi
mohamedriswan
Ensign mohamedriswan Ensign
6
KarimBenameur
Ensign KarimBenameur Ensign
4
Back to EcoStruxure Automation Expert / IEC 61499 Forum
Reinard
Crewman Reinard
Crewman
Posted: ‎2024-08-14 05:12 AM
1573
Good day,
I am trying to run a softdPAC image on my Raspberry pi. I have managed to get it working with EAE v22.0 no problem. However, running v23.1 I get issues with the docker images. I have tried doing the installation multiple times, but still get the issue. Docker is complaining that the image architecture was not designed for arm64. When I do the same install on Debian 12 it works. Is there something I missed for EAE v23.1? I did run platform_install.py during the installation.. See image below:
For the time being I was able to run multiple pi's on SoftdPAC v22 succesfully, and using v22 libraries in EAE v23.1 does work, however there are a couple of things not 100%. For example running an HMI does not function with library blocks. Events are working though.
  • IEC 61499
Reinard
Crewman Reinard
Crewman
Posted: ‎2024-09-24 02:13 AM
In response to alexcarey
The issue was solved using an older Raspbian image, I'm not sure what was exactly wrong with the version I used. I saw the same install issues with Docker, but the SoftdPac worked and I could download my application to the Pi
Reinard
Crewman Reinard
Crewman
KarimBenameur
Ensign
Posted: ‎2024-11-15 07:18 AM
Hi Reinard,
this warning is known and will not prevent Soft dPAC to run. Multiple reason can explain why you are not able to run. First please check the time of your PI  as every time you reboot it will be lost and Soft dPAC will not run if your date and time is not correct.
Please notice that you must check that pre requisite are met (check user manual) like docker version etc ... It will depends on you Soft dPAC version. If you are using a 24.0 (recommended) a script will do check and optimization for you (platform_install.py).  Basically you must do the installation (install.py) and create the manager (Application_manager.py) then the Soft dPAC must be create for EAE (first securing the PI and then create a Soft dPAC instance).
Please provide some logs if you encounter some issue.
