PID Feedback
EcoStruxure Automation Expert / IEC 61499 Forum
Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
  • Industrial Automation
  • EcoStruxure Automation Expert / IEC 61499 Forum
  • PID Feedback
mohamedriswan
Ensign mohamedriswan Ensign
6
KarimBenameur
Ensign KarimBenameur Ensign
4
Back to EcoStruxure Automation Expert / IEC 61499 Forum
DP-JYC
Lieutenant JG DP-JYC
Lieutenant JG
Posted: ‎2024-09-30 11:08 PM
PID Feedback
While I was looking at the online doc (great thing!), I would like to give some feedback about my favorite FB: "PID".
A/ Direction switch
This is a very specific parameter, and should be very difficult to change when the plant is operating. Here, if I do a single click by accident, I switch mode and it's DANGEROUS! Setting it with a combo box for example, you will need 2 clicks to change it. => It's adding security! (UI/UX 😉!). You can also probably put this in an Advance tab.
B/ Direction vocab
A direction is not "true/false" a direction is "direct/invert"!
In the doc, at least it would be great to mention!
Direction for detected error calculation:
False = Calculation based on Pv-Sp
True = Calculation based on Sp-Pv
C/ Looking at the popup, I see so many odd things
C.1/ While tunning % is possible, it's quite rare! Put your demo PID with a °C PV or mm or m3, but not %.
C.2/ On the top I see "current Mode" then "Current Owner". On the bottom I see "Owner" then "Mode". For consistancy, can you put the same order?
C.3/ In Owner: "Operator / Program" could be apparented to Manual / Auto. Or "I have the hand, I don't have the hand".
In Mode: "Auto / Manual", could be apparented to "I don't have the hand, I have the hand".
=> Why not having them on the same side ?! To keep consistancy.
C.4/ Owner & Setpoint are things that works together. Why having mode in the middle?
C.5/ I guess that with this state (Mode Manual), I can't change the Owner. So it should be disabled?
  • Libraries
Replies 0
