Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
Posted: 2024-09-24 04:11 PM . Last Modified: 2024-09-25 08:10 PM
Hi
I am novice in Ecostruxure Control Expert and while adding I/O modules to configuration, it asks me about "Topological Address". There are 2 options to choose :
I/O data type : Topological
I/O data type : Device DDT
Can anyone help me about these 2 to options and what is their difference ?
Posted: 2024-09-30 07:13 PM
Modicon M580 has moved towards tag based addressing rather than a specific address. In some cases where we consider legacy migrations we may choose to use an address based system.
By default all IO modules will generate a device data structure (Device DDT) which provides health status and actual values such as input value or an output value depending on the module. For an addressed based option (topological) a digital input channel would be expressed as %I<rack>.<slot>.<channel> e.g. if it was the first input on an input card which is in the CPU rack (rack 0) and in the third slot (i.e. slot 2, 0 being the first slot) the address of the input would be %I0.2.0. Alternatively the last output on a 4 channel analogue output card in the fourth rack and 8th slot is %QW3.7.3.
Generally go for the device derived data structure as the default.
