De-rating of ATV630/650 if installed using a Flange kit
EcoStruxure Automation Expert / IEC 61499 Forum
Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
  • Industrial Automation
  • EcoStruxure Automation Expert / IEC 61499 Forum
  • De-rating of ATV630/650 if installed using a Flange kit
mohamedriswan
Ensign mohamedriswan Ensign
6
KarimBenameur
Ensign KarimBenameur Ensign
4
Back to EcoStruxure Automation Expert / IEC 61499 Forum
WillTeow
WillTeow
Cadet
Posted: ‎2024-09-24 08:18 PM . Last Modified: ‎2024-09-25 08:20 PM
If an ATV630/650 is installed inside an enclosure using a Flange kit NSYPTDSx, with the rear power section dissipating heat into the ambient air (50 celsius), does the VSD, inside the enclosure, require de-rating due to the ambient air temperature being 50C plus the VSD control section dissipating heat into the enclosure?
  • faq
Replies 0
