Need Help: Connecting EcoStruxure Automation Expert with Node-RED via OPC UA
EcoStruxure Automation Expert / IEC 61499 Forum
Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
  • Industrial Automation
  • EcoStruxure Automation Expert / IEC 61499 Forum
  • Need Help: Connecting EcoStruxure Automation Expert with Node-RED via OPC UA
mohamedriswan
Ensign mohamedriswan Ensign
6
KarimBenameur
Ensign KarimBenameur Ensign
4
Back to EcoStruxure Automation Expert / IEC 61499 Forum
Mohamed_hamou
Mohamed_hamou
Cadet
Posted: ‎2025-03-24 08:19 PM . Last Modified: ‎2025-03-27 12:27 AM
407
Hello everyone,
I am working on integrating EcoStruxure Automation Expert with Node-RED using OPC UA, but I am facing some challenges.
What I Have Done So Far:
  • Enabled the OPC UA server in EcoStruxure Automation Expert.
  • Used UaExpert to connect and retrieve variable IDs/tags.
  • Followed Schneider Electric’s official YouTube tutorials.
Issues I'm Facing:
Despite these steps, I am still unable to establish a working connection with Node-RED. I would really appreciate any guidance, troubleshooting steps, or resources to help resolve this issue.
Thank you in advance for your help!
Best regards,
Mohamed
  • IEC 61499
theo.bagieu
Ensign theo.bagieu Ensign
Ensign
Posted: ‎2025-04-10 12:07 AM
Hi @Mohamed_hamou
As Node-RED is not part of our official supported product, i don't have official troubleshoot for that topic.
The advises i can give you is to have a step by step debug approach :
First of all, in secure/isolated network, try to disable the OPCUA encryption ( Security Policy = None ). It will ensure that you don't have issue with Certificates, or encryption incompatibilities, and it will help you to have clear view of data packets for debug.
Can you check (and maybe share) the logs you had both from EAE side, and Node-RED side. Can you also precise the EAE device you're using ?
Then if logs aren't enought explicit, if you're confortable with Wireshark you can intercept the packets between your nodeRed instance and EAE to indentify what's wrong here.
Can you also precise which node (Library) you're using ?
