Controller firmware
EcoStruxure Automation Expert / IEC 61499 Forum
Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
  • Industrial Automation
  • EcoStruxure Automation Expert / IEC 61499 Forum
  • Controller firmware
mohamedriswan
Ensign mohamedriswan Ensign
6
KarimBenameur
Ensign KarimBenameur Ensign
4
Back to EcoStruxure Automation Expert / IEC 61499 Forum
Sean1
Crewman Sean1
Crewman
Posted: ‎2025-01-16 07:15 PM
901
Controller firmware
Please excuse lack of knowledge this is all new for me. How do I know when the controller is in need for a firmware update and how do I do it?
mohamedriswan
Ensign
Posted: ‎2025-01-17 04:17 AM . Last Modified: ‎2025-01-17 04:18 AM
Hi Sean1,
To update the firmware, we need the Automation Device Maintenance Software, and the firmware package will come with the EAE setup file. Please refer to the attached document for the reference to upgrade firmware .
Sean1
Crewman Sean1
Crewman
Posted: ‎2025-01-19 02:19 PM
In response to KarimBenameur
Perfect thank you
KarimBenameur
Ensign
Posted: ‎2025-01-17 02:44 AM
878
Hi Sean1 and welcome.
Firmware update is only required with a new version of EAE (Ecostruxure Automation Expert). All controllers in your distributed system have to be at same firmware level i.e. must  be compatible with the version of you EAE built time (the engineering tool) installed on your PC to build and deploy your EAE solution.
mohamedriswan
Ensign
Hi Sean1,
Sean1
Crewman Sean1
Crewman
Perfect thank you
