Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
Posted: 2024-11-28 07:54 AM
How to Access symbolic links through CAT blocks in an Application? When I implement symlinks etc. In main app view I van drag and drop the symbolic links to associate them. But when I make same functions to Cat block and try to access The values from another Cat, The values dont change and The symlink for example 'APP1.CAT1.variable1' is not seen connected in symbolic link view.
Posted: 2024-12-02 08:56 PM . Last Modified: 2024-12-02 08:57 PM
What type of CAT are you using: composite or SubApp CAT? Typically, you can't drag and drop symlinks inside the CAT; you can only copy and paste the symbolic link name, which works for the composite CAT type.
If you’re using the SubApp CAT, the symlink syntax will vary. For example:
you can use the below function block to find the symlink name inside the CAT
Posted: 2024-12-04 12:14 AM
I tested with the VALFORMAT to identify the name, in my case RES0.CAT1.Valve1.progloc, I see it connected in the symbolic link of RES0. But it doesn't cahnge the values. Also tried with just accessing variable with symlinkdst and src in these two CATs, it shows connected in RES0 symbolic links but doesn't communicate in the system to cahnge the actual value. I use composite CATs. Also tried with different names RES0.APP1.etc
Posted: 2024-12-16 02:16 AM
Have you set the "ModeSignalEn" option to True in the offline parameters? When attempting to change the mode using a symlink, this parameter must be set to True.
Posted: 2024-12-16 11:40 PM
I changed the "ModeSignalEn" to True, but can't still access/change values of that valve from the other Cat block.
Posted: 2025-01-16 03:01 AM
Normally, it should work. The Resource name should be added in the symbolic link, I use it for simulation, example bellow:
Posted: 2025-03-08 10:22 AM
Hello Emli1,
You can try like this:
