How To Configure Modbus TCP Data in Ecostruxure Automation Expert
EcoStruxure Automation Expert / IEC 61499 Forum
Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
  • Industrial Automation
  • EcoStruxure Automation Expert / IEC 61499 Forum
  • How To Configure Modbus TCP Data in Ecostruxure Automation Expert
mohamedriswan
Ensign mohamedriswan Ensign
6
KarimBenameur
Ensign KarimBenameur Ensign
4
Back to EcoStruxure Automation Expert / IEC 61499 Forum
aliffdani
Crewman aliffdani
Crewman
Posted: ‎2025-01-25 06:54 PM
1569
Hi, I have a problem regarding on how to configure modbus tcp in Ecostruxure Automation Expert. In my project, I poll data from relay. At relay, the data communication used is RS485, and i convert it to modbus tcp via converter and connect it to Modicon M251. I do not know how to configure the modbus tcp in Ecostruxure Automation Expert. Here attached the relay data for your reference.
Replies 4
KARTHICKR
Ensign KARTHICKR Ensign
Ensign
Posted: ‎2025-01-27 09:05 PM
Hi Aliffdani, please refer the below link for Modbus TCP configuration
EcoStruxure Automation Expert User Manual
mohamedriswan
Ensign
Posted: ‎2025-01-27 11:28 PM . Last Modified: ‎2025-01-27 11:30 PM
Hi Alif,
Please refer to the video link below for configuring the Modbus Master TCP. For the Slave configuration, you will need to select the Slave library; all other steps remain the same.
How to Configure a Modbus Master in EcoStruxure Automation Expert v21.0 | Schneider Electric Support
KarimBenameur
Ensign
Posted: ‎2025-02-17 06:59 AM . Last Modified: ‎2025-02-17 07:00 AM
Hi Aliffdani, I though that M251d had a serial port and so why using a converter and not use directly Modbus RTU ?
As your M251d  is a client and your relay is a server you need the library Standard.IOModbus, on HW Configuration Editor add your Bus Master Standard.IO.Modbus.MODBUSSERIAL. On property, you can configure communication speed, parity etc and add a modbus coupler and HW CAT to read coil register etc ...
Please refer to mentioned documentation.
YogeshTayade
Crewman YogeshTayade Crewman
Crewman
Posted: ‎2025-03-08 09:43 AM
Hello Aliff,
Are you still looking for a solution?
Please feel free to contact me here
