Modifying device alarms in the Active Alarms view
Device Alarm Configuration view
  • EcoStruxure IT Help Center
  • DCE alarm configuration
  • Device Alarm Configuration view
  • Modifying device alarms in the Active Alarms view
  • Mark as Read
  • Modifying device alarms in the Alarm Configuration...
  • Edit Device Alarm Configuration display
EcoStruxure IT Support
Request Support
Back to Device Alarm Configuration view
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:14 AM
  1. In the Active Alarms view in the Monitoring perspective, select an alarm, and right-click to select Edit Alarm Configuration.
  2. Select This Instance to modify the device alarm configuration on the device reporting the selected alarm only, or select All Instances to simultaneously modify the configuration on every device for which that alarm is defined, regardless of whether those devices are currently reporting an alarm.
  3. Click OK.
