Edit Device Alarm Configuration display
Device Alarm Configuration view
  • EcoStruxure IT Help Center
  • DCE alarm configuration
  • Device Alarm Configuration view
  • Edit Device Alarm Configuration display
  • Mark as Read
  • Modifying device alarms in the Alarm Configuration...
  • Modifying device alarms in the Active Alarms view
EcoStruxure IT Support
Request Support
Back to Device Alarm Configuration view
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:12 AM
Specify how device alarms reported by monitored SNMP or Modbus devices are displayed.
You can modify severity and recommended action, add a custom description, and disable or reenable device alarms for the device groups, devices, or device alarms selected.
You access the display from the right-click menu in the Device Alarm Configuration view or the Navigation view in the Alarm Configuration perspective.
When you access the display from the Navigation view, all the device alarms associated with the device groups or devices selected are configured simultaneously.
When you access the display from the Device Alarm Configuration view, you can specify which device alarms associated with the device groups or devices you selected in the Navigation view to configure. You can expand the selection to view and configure device alarms by alarm type, alarm name, or by one or more devices reporting that alarm.
Note
With the exception of the Enabled option, device alarm settings you modify do not apply to active alarms. The modified settings will apply the next time the alarm is triggered.
Element Description
Enabled Select to enable the device alarm, if it is disabled.
Note
Device alarms are enabled by default.
Severity Select the severity you want associated with the device alarm: Information, Warning, Error, Critical, or Failure.
Description The alarm description provided by the device. You cannot modify this description.
Custom Description Provide a description you want included in the device alarm notifications.
Recommended Action The recommended action provided by the device. You can modify the recommended action to include instructions you want in the device alarm notifications.
Reset to default Reset the recommended action to default, if it has been modified.
