Data Center Expert VM ESXi compatibility
Data Center Expert Virtual Appliance (VM)
  • EcoStruxure IT Help Center
  • Data Center Expert Virtual Appliance (VM)
  • Data Center Expert VM ESXi compatibility
  • Mark as Read
  • DCE sizing guide
  • DCE performance troubleshooting guide
  • About changing hardware resource settings for the ...
  • How to increase hard disk space on a DCE VM
  • Deploying and configuring a Data Center Expert vir...
  • Fault tolerant configuration guidelines
  • Hardware resource configuration guidelines
  • Migrating a Data Center Expert hardware server to ...
  • Minimum and maximum Data Center Expert virtual app...
  • Data Center Expert server equivalent configuration...
  • Upgrading a Data Center Expert virtual appliance d...
  • Video: Deploying the Data Center Expert Virtual Ap...
  • DCE sizing guide
EcoStruxure IT Support
Request Support
Back to Data Center Expert Virtual Appliance (VM)
  • Mark as Read
Picard EcoStruxureIT
‎2023-01-13 07:27 AM
Last Updated: Sisko JLehr Sisko ‎2024-02-13 12:23 PM
Starting with Data Center Expert 8.1.0, VMware ESXi 6.7 is used as the reference virtualization platform for the Data Center Expert virtual appliance.
In Data Center Expert 8.1.0 and higher, the OVA is created using ESXi 6.7. Only E1000E and VMXNET3 network adapters are supported.
These instructions are for DCE versions 8.0.0 and older only
VMware ESXi 4.1.0 was used as the reference virtualization platform in DCE versions 8.0.0 and older.
The Data Center Expert 8.0.0. and older OVAs were created using ESXi 4.0. It supports version 4.1 and can run on versions up to 7.x but may have decreased capabilities on versions above 4.x.
You can upgrade the VM compatibility with later versions in the VMware UI, particularly to increase the number of CPUs extended to a DCE 8.0.0 and older VM.
When DCE version 8.0.0 and older is deployed to a ESXi 7.0 host, CPUs are limited to 8. After upgrading the VM compatibility, you can increase the CPUs based on the capabilities of the ESXi host.
  1. Power off the VM in vSphere.
  2. Right click the VM and select Compatibility > Upgrade VM Compatibility.
  3. A warning is displayed about reverse compatibility that advises you to make a backup. When you are ready, click YES.
  4. Select the compatibility version for the VM upgrade. Choose the version that matches your ESXi environment. Click OK.
Your VM is now compatibility with the ESXi version you selected, and you can increase the number of CPUs extended to your DCE VM.
