DCO network firewall port details
DCO Security
Support for Data Center Operation version 8.3.x ended on January 1, 2022. Upgrade to EcoStruxure IT Advisor.
  • EcoStruxure IT Help Center
  • IT Advisor
  • DCO
  • DCO Security
  • DCO network firewall port details
  • Mark as Read
  • Resetting user password on the DCO server
  • DCO security
  • Changing SSL certificate on the server
  • DCO security
EcoStruxure IT Support
Request Support
Back to DCO Security
  • Mark as Read
Picard EcoStruxureIT
‎2019-10-07 05:42 AM
Network protocol and ports (incoming ports allowed by the firewall)
The firewall provides basic protection. If protection against sophisticated attacks is required, using a dedicated firewall product is recommended.
Communication across a NAT firewall is not supported.
The following protocols and ports are used by Data Center Operation:
Protocol
Transfer protocol
Port(s)
Network Credentials/Access Encryption Comments
HTTP / HTTPS
TCP
80 / 443
Latency less than 200 ms, bandwidth minimum 1 Mbps. Bandwidth usage between client and server heavily depends on size of solution, number of users and the type of operations done to the solution.
Manually created user and password (default apc/apc)
Authentication server integration support
There is no option to reset client user password
Password policy is not implemented in DCO but can be enforced using Authentication servers. Password can be ASCII format and numbers
Only using HTTPS
TLSv1.2
Communication between server and clients. HTTP can be disabled or redirected to HTTPS for improved security.
SNMP UDP 161 Basic system information and status of the Operation service will be exposed. More information can be found here
The SNMP server can be disabled using the Server Configuration interface
SNMP community string is default "public" For added security from v7.3.6, disable SNMPv1 and configure SNMPv3. More...
PostgreSQL TCP 5432 Depending on system integration the bandwidth requirements should be specified accordingly. As specified in external system ETL configuration
Default MD5 authentication
Otherwise depending on database integration created
ETL communication between database and server
Webmin TCP 10000 Very limited bandwidth requirements in normal operation. Downloading/uploading backups will increase the bandwidth requirements significantly.
Manually created user and password during installation
User password reset instructions
Yes Server configuration interface at https://<server ip>:10000
Ping ICMP   Will reply to ping requests
External systems related protocols (outgoing, default (can be edited))
HTTP TCP (SSL/TLS) 80 (443)
Depending on system integration being used.
For Data Center Expert it is estimated that every alarm will be around 2000 characters in size. Sensor data has approximately the same size but is transferred more often (depending on the integration configuration). The alarm and sensor data are bidirectional communicated with the majority of data going to DCO. A catch-up job is run on a hourly basis (configurable) this job will poll number of active alarms * 2000 chars.
As specified in external system configuration Depending on system integration VMware, SCOM, Cisco UCS
SMTP TCP 25 Email traffic from the DCO is limited and "user generated" via e.g. work order execution, some system configuration etc. As specified in external system configuration Not supported communication with e-mail server
DNS TCP/UDP 53 Very limited traffic and bandwidth requirement As specified in external system configuration Not supported DNS server communication
NFS TCP/UDP 111 Depending on system integration As specified in external system configuration Not supported by protocol NFS mounted external drive
NTP UDP 123 Very limited traffic and bandwidth requirement As specified in external system configuration Depending on system integration NTP server communication
SMB TCP/UDP 139 Depending on system integration As specified in external system configuration Depending on system integration SMB communication to NAS/SAN
CIFS TCP 445 Depending on system integration As specified in external system configuration Depending on system integration CIFS communication to NAS/SAN
NFS TCP/UDP 2049 Depending on system integration As specified in external system configuration Not supported by protocol NFS communication to NAS/SAN
