Valid blade configuration
Configuring blade solutions
Send InviteCancel
The system ensures a valid configuration and guides you in placing blades in the bays of the blade enclosures based on the configured physical properties of the equipment.
Supported configurations
Any combination of full / half height with double / single width blades.
Amount
The system validates that there are a sufficient amount of bays available in the blade enclosure to contain the amount of bays that the blade servers take up.
Product family
If the blade enclosure has been specified to be of a certain brand or product family, only blades with the same properties can be placed in it. If there is no product family defined for the blade enclosure, only blades that have no product family defined either can be added to this enclosure.
