"Validation failed for property 'PrimaryPassword'" when renaming an Automation Server
  • "Validation failed for property 'PrimaryPassword'" when renaming an Automation Server
  • RobertAndriolo
    RobertAndriolo
  • Benji
    Benji
‎2018-09-06 08:36 AM
When attempting to rename an Automation Server, the following error is shown:
Validation Error
Validation failed for property 'PrimaryPassword'. Path: '[server path]'. Type 'Password'
Cannot set property value to null because the property is not nullable.
Automation Server
The Automation Server has been cloned using a backup of another Automation Server, and in that process the SMTP server passwords have been set to null.
Configure a password for the primary and secondary SMTP server. It does not matter what the password is set to.
Tags (2)
  • 18862
  • qc31509
