"Server Busy" error when attempting to edit a Menta application from the system Plug-In
  • "Server Busy" error when attempting to edit a Menta application from the system Plug-In
  • PeterLarsen
    PeterLarsen
‎2018-09-06 03:57 PM
The following message appears after approximately 30 seconds when you attempt to edit a Menta file from the system Plug-in.
Windows 7
Vista 5.1.5, 5.1.6 and 5.1.7
The login screen does not come to the forefront when required
Use the ALT - Tab key combination to scroll through the open windows.
Select the logon screen and continue with the normal process.
  • 7442
